Bit harsh Tony, I would imagine that there are quite a few electricians in this country who have no understanding of Medium Voltage system operation.
You also have to remember that it's a Yank you're talkinng with.
I watched an episode of CSI, and apparently if you cut the earth pin off of a plug, reverse the polarity of an a.c. drill then stick a nail or screw in someone's boot, they will die when they use that drill.
correct I am a yank
ive been a spark for close to 40 years. i am currently an industrial spark but do a a fair amount of residential work as well for my fathers construction company.
not knowing your terminology does not make me a D.I.Y.
in this respect gents ive come to this forum as an apprentice to learn more about methods and regs in your country.
its the one reason i joined.
our residential voltages are stepped down to a lower voltage level but the current levels are higher.
and its the current that packs the wallop. now can you see why this post is named safety
new install in a new construction calls for a 110/240 volt 200 amp service
lighting limited to 110 volt at 15 amp maximum. utility 110 volt limited to 20 amp.
and 240 volt limited to the requirements of the appliance (range, dryer, water heater,)
gfci/rcd's protected outlets in kitchens, basements, laundry rooms, and garages (although you can also install them in bathrooms I prefer no outlets at all in the bathroom) but prefer to build a vanity table instead (away from any water)
outside outlets are also protected by rcd's but placed in weatherproof boxex (preferebly this type)
Teddico/BWF: Weatherproof “While-In-Use” Receptacle Covers
Thanks for that gnu.
One thing I've always wondered about is your 110V.
As I understand it, this is not split or 2phase (55V-55V) as is used in the UK,but single phase 110V and neutral.
I also understand that your 240V (I thought 220V), is supplied by two 110V phases similar to how we supply 110V.
Is this the case, or have I got it completely wrong?
its actually a single phase 240 split into 2 legs from inside the transformer mounted on the poles for residential
3 phase power for commercial and industrial drops from the transmission lines (fused) to substation transformer installations and is then routed to the switch gear then to additional transformers and main control systems
Outside a typical house you can see a pole mounted transformer mounted on the electricity pole. It's a step-down transformer used to convert the high voltage (7200 or 14400 volts) down to the standard 120/240 volts used in the home. The high voltage distribution lines (7200 or 14400 volts in the US) attach to the two bushings on top. The low voltage wires (two hot wires and one neutral) attach to the three terminals on the side. The secondary winding is center-tapped and grounded, making the two end conductors "hot" with respect to the center tap. These wires run down to the electric meter and breaker panel inside the building. Connecting a load between either hot wire and the neutral gives 120 volts. Connecting between both hot wires gives 240 volts. This is the setup for single-phase electric power in the United States. If three-phase power, three pole mounted transformers of the appropriate KVA rating are wired in either a wye or delta transformer bank.​
Single phase pole mount transformers are usually rated from 167 kVA up to 500 kVA with high voltages ranging from 2400 up to 34500 gnd wye. Low voltage of 600 Volts and below . The available Temp Rise is 55/65°C or straight 65°C.
thats why ive named this post safety
i realize that our systems are radically different
but my point is their is no excuse for not following safety procedures
many of the boards we have to change here date back to the 40s and 50s some systems went back even further
we have to prove to the home owner that what they have (the old crap) is not safe
but we also have to work with whats available as far as new products, and we have to convince the homeowner that the cost is worth it
and if it was good for continued service?..
god help you if lets say you ever worked for me and you ripped something out on the pretense that it was `unsafe`...or it was `old crap`...yet it was perfectly good for continued service..
its the kind of thing i just cant stand penguin ...
theres a lot of 14/15 edition install working quite happily over here..with their BS3036s for overcurrent/overload...
no doubt you will have similar setups there...just caus its a bit `senior` doesn`t mean you condemn it...
Again you misunderstand what I mean when I said old crap I meant wiring that has failed megger testing and is old enough to crumble in your hands. This is unsafe by any means.
Also we do not have the authority to condemn a working installation. Only the fire marshal can do that.
Please do not be abusive to me remember I am from a different country
