Discuss SAK din rail terminals in the Industrial Electricians' Talk area at ElectriciansForums.net
Hi just wondering if anyone would know this, regarding sak din rail terminals when are separation plates really required obviously at the end of the sak so no exposed terminals but are needed between different type terminals such as live and neutrals or is this just a preference ? Thanks in advance
Aside from at the end of a row I would probably include one when placing a smaller terminal next to a larger one if this would leave metal work in the larger one exposed.
Between connections for outgoing feeds is where I would use them, they make it obvious where each separate circuit is. Some of our terminal chambers had up to 2000 SAK terminals.
We put them between terminals of different voltages and circuits
E.g.
L/N
0v & 24v
often these are in linked rows
using screw in jumper/ link bars
Segregating with an end cover ensures one jumper can't touch the next one
motor / mains power 240v /400v terminals are segregated from other terminals/ circuits and usually have combination of earth terminals, end covers and stops on both sides .
Reply to SAK din rail terminals in the Industrial Electricians' Talk area at ElectriciansForums.net
Ferrets are known for being small, resourceful, and incredibly clever. They can solve many problems by fitting into tight spaces and doing jobs us...
Hi I've been planning to fit an outdoor junction box at the front of my house to hide a large brickwork hole and properly house the wiring...
Hello everyone, Following on from my previous post where I received advice on taking a spur off a 40a feed (thank you). I performed the work...
Hi all! I'm not a spark but know enough to be able to install off grid solar etc. I've just purchased a new house and have noticed the consumer...
5K
Hi, while carrying out an EICR at a farm cottage on Friday i came up against a problem early on. Whilst measuring the Ze the reading i obtained...
