Search the forum,
Discuss SDS & hole saws in the UK Electrical Forum area at ElectriciansForums.net
Horses for courses.
I have my Dewalt 18v combi for light stuff, a cheap 110v Ryobi SDS that I've had for about 7 years and a Milwaukee core drill I've had for longer, that I use for well... for core drilling.
I used the Milwaukee to put a 4" hole through 2' of black basalt not that long ago.
I can assure you even with a decent core bit it was nothing like a hot knife through butter.
I work on the principle that if I use each drill for what it's designed for then I'll still be using them happily for years.
until the 'labourer factor' or the 'van's 3 flights of stairs + 5 min walk away factor'!
Horses for courses.
I feel your pain.
It's jobs like this when you need a rig to fix the machine to so all you have to do is turn a handle to feed it through the wall.
Not something you would want to buy on the off chance you'll need it someday, but maybe worth hiring now & then.
http://www.edcoinc.com/core-drill-rigs-36.html
Or the 'yet another thing to load in the morning, unload at the job, load at the end of the day, unload back home' factor. Exhausted and out of time before any work has even been done!
Reckon if my 18V combi will cope with the occasional solid board access hole, then so will my SDS... If I need to do loads on a job then maybe I'll hire...
you need a rear handle 1000 watt elu drill and a diamond tipped cutter mate theres no magnetic slip clutch, if it binds you get a busted arm
the nose of the elu drill will go through the hole that the cutter bores if its a 4 inch hole for fan ducting/ soil pipe
New posts
Reply to SDS & hole saws in the UK Electrical Forum area at ElectriciansForums.net
I’ve always been alright with the knockouts provided for Fusebox consumer units but I’ve got a job coming up where I don’t want to use the large...
A friend of mine is looking to have an electric shower fitted and has floorboards up already (mostly, long story). Anyway there is a run of 2.5mm...
So back in the early around year 2000, I was a data networks installer and had a Bosch 24v SDS drill, it was awesome, did pretty everything I...
im not sure where to post this.. and I need help [ I posted here because i guess Heating systems may need a hole this big , and this is the only...
I was working alongside the plumber yesterday. I had to drill some 32mm holes through joists. I always use my Makita 481 high torque drill will a...
