Discuss SECTT TEST STUDYING? in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
Thank you for the response, this will help me a lot I appreciate it.If you go to this website and check out P 16 it should clear things up for you a little. http://www.sectt.org.uk/documents/SECTTApprenticeshipandAdultTraineeshipSchemeBrochure_000.pdf
the rest of the brochure is worth a read too it outlines what will happen and what to expect.
I done my apprenticeship through SECTT and the SJIB all of the learning materials we needed for the actual apprenticeship where provided.
Join the trainee section and check out what goes on in there.
Feel free to PM me for advice etc as well.
It might be a good idea to pick up a copy of Guidance note 3 I think that's the only thing we never got but at first you wont really need this. Inspection and Testing is, in my opinion, where a lot of sparks fall down, there's plenty of videos in the trainee section that will be helpful with inspection and testing. If you start early you'll be pretty good at it by the time it actually gets around to learning about it and should fly through.
No worries, Good luck and all the best in your career.Thank you for the response, this will help me a lot I appreciate it.
Reply to SECTT TEST STUDYING? in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
