Discuss Security Light Component Fail in the Lighting Forum area at ElectriciansForums.net
Wilko
Hi - today I was called to take down a 50W motion detecting security light that was always on. Rather than just bin it, I’ve cut the sensor open and found the charred remains of some-component-or-other in it. A smoking gun, you might say. What do you think the toasted component 7C5B7440-860C-4545-9F83-E88EB7FF7A7D.jpegwas? It might’ve been across the relay, which is out of view on the other side of the board.
I bench tested the light was “always on” prior to cutting the sensor open. And so it initially remained afterwards. Then I cleaned up the area and guess what, sensor now appears to work as intended. Hmmm.
Had similar with a outside motion detector at my local, spayed some switch cleaner in it by surgically forcing the tube trough the edge of the lens. Its been alright ever since 12 months and counting !
Reply to Security Light Component Fail in the Lighting Forum area at ElectriciansForums.net
I have a question for you all, We recently moved, and the old house had the analog meter on it, the new place has 3 structures on the property.. a...
Hello all, my first post here and I'm looking for some advice. We recently moved house and the external garage has a couple of security lights on...
My view on life, in any field, is not to produce more but to consume less. Everybody told me this is a very eccentric weird mentality. Perhaps...
Hi We've just moved in to a new house and it's got 3 outdoor security lights in the back garden. I've tried to trace the wiring back inside but I...
I hear many views of people who believe that DPF's and CDPF's fitted to their vehicles are a problem and many people resort to removing them, or...
8K
