U
Ucalagon
Dear Experts - I have a Clarke's Industrial fan and would like to use it to cool our large conservatory. It's got a 3speed setting but even slowest is moderate Windy Day mode. It's rated 350w. I'm having trouble locating a dimmer that's rated 450w ish. I don't intend to run it for extended periods on Gale Force 8 but would appreciate any help. I see I can get 400w light dimmers. Are they suitable? Temperatures in conservatory often exceed 30 deg C.
All help welcome. DW
Welcome to the forum :).
I will ask admin' to give you a DIY under your name, this allows members to realise you electrical level and tailor their advice accordingly.
What is the voltage of this industrial fan?
Many lighting dimmers will not function correctly with a heavily inductive motor load, however there are phase-angle power controllers especially designed for fan motors such as
Speed controllers - - Electronic speed controller - EFSC
However not all fan motors are suitable for electronic speed control. It will depend to an extent on the existing internal speed control arrangement and whether a run capacitor is fitted, assuming it is an induction motor.
The problem with using a dimmer instead of a fan speed control is that a dimmer has no minimum setting whereas a fan speed controller won't go below a certain speed to prevent the motor running into a stall condition or running so slow it overheats due to lack of ambient air-over or slow running of the cooling fan on the back of the motor.
Seeking dimmer for 350w Industrial fan
Ucalagon,
Marvo,
