Discuss shed light - IP rated? in the Australia area at ElectriciansForums.net
Q
quickspark
hi guys,
i want to fit shed light and use this job for niceic assesment. i am not sure what light fitting i should use, shall it be ip rated for dampness or something? what would you recommend?
thanks a lot
Reply to shed light - IP rated? in the Australia area at ElectriciansForums.net
Hi all, I'm planning on adding some lighting to an old stone shed, there's currently a 2.5mm² SWA supply to the shed only supplying one IP rated...
Hi, I'm looking to get the lionshare of a small shed wired before a friendly electrician does the needful. I'm a confident DIYer, but I would...
Hi, I'm a DIY'er looking to build a 6x8 shed in my backyard in Colorado. I'm installing a gravel pad first, with 4 concrete Sonotube...
Hi guys, I have supplied my Shed with a 6mm SWA cable into a nice consumer unit. In there I have a 6Amp MCB for the lights and a 16 A supplying a...
Hi, I'm running a 70ft underground UF cable in 3/4 inch PVC conduit to 2 sheds. The sheds are 3ft from each other. I'm just a DIYer enthusiast so...
