T
Thomas123
I've acquired 4 core 2.5 swa for a supply to my shed, approx 20 run.
Seeing as I have a 4core, would you just use it as a 2.5 and put it on a 20a rcbo, using 2 cores for the earth plus swa, (I'm not wasting a core lol) or double the cores up in parallel and have it on a 32a? Using the armour as the cpc. 20a is ok for now but if I ever need it, it's there ready.
I'm not tt'ing it either as its a wood shed sat on top of decking.
double the cores. use armour as cpc, 32A MCB. but you may need a 10mm bonding conductor if you have extraneous in the shed.
It's a tncs supply, but there are no extraneous parts as its a "wood shed sat on decking" :)
Just a pathetic attempt at humour Glenn :)
Haha I guessed it was a joke mate, so it wasn't pathetic.
I was hoping it would cause more a heated debate than this. :)
I knew what I was going to do from the start, just wanted to see other people's opinions. 20a rcbo, as ill never use more than this, a light and a few sockets is all that will be in there. I'm not the type to go down the shed on a lathe for hours after an argument with the misses lol.
I,d use a 4mm2 on a 20 amp supply myself LOL he he
Thomas is back after his ban i see.. The 400v red socket thread was a tad funny to be fair
You could use 2 cores for the supply, armour as cpc, then use the other 2 cores to switch the lights from the house.
