W
walec
Hi All,
Anyone every run power to a shepherds hut? There are 4 double sockets and a light inside, (which are all pre-wired to a 32A 3pin outside socket), its 60 meteres from the house which is a TT Installation as its in the middle of some woods. For obvious reasons I dont want to bury the cable but there is no fencing, only hedges so I am looking for ideas? Thanks Walec
Well if there is nowhere to clip to, and you don't want to bury it, why not? then your left with one choice really and that is to take it out by poles, not the Eastern European kind.
"There are 4 double sockets and a light inside, (which are all pre-wired to a 32A 3pin outside socket)"
Now that is intriguing. Do they use a 60 metre extension lead that as a plug both ends!!!!, not sure what you mean there.
Are you going to be fitting a new CU inside the hut?
Sounds like it may be a transportable unit, section 717 may apply.I assume the '32a plug' is an inlet connector wired to a CU in the unit?
I have asked the owner for information from the manufacturer because its a little odd. The sockets are wired on a ring but straight into the female socket on the outside underneath, so is the light radial, no CU! It appears that you are expected to just plug it in from the house, yes a three pin plug on each end much like camping! but they want to use it as an office which has a bunk bed in!...Its beautifully made but little attention has been paid to the electrics other than to run the cables in, thats what has me stumped! It will be interesting to hear what the manufacturer says, I dont know who thet are yet.
Well the old "death trap" lead of a male plug at each end definitely needs to be got rid of.
You can buy proper male sockets as used in caravan hook ups which would be a better way to do it. Also You will need to revamp the inside of the hut as it's not an ideal design.
What was the "extension lead" plugged into at the origin, and what size was the extension cable?
You dont nec. need a CU in there (but prob best). Light might be FCU off sockets. Burying would be nightmare rhrou a wood (roots) unless u use mini digger, like the pole idea
Forget the poles and secure the cable to the trees (ready made poles) LOL :)
Does the origin have RCD protection and what do you propose about earthing?
Like the poles idea, too many trees and roots for digging trenches. Origin does have RCD but no room in board. I am thinking new spilt tails, new main switch with MCB, then SWA to hut and put in RCD CU with new Earth rod at the hut.
The customer is insisting I can not put a CU in the hut as it will mean a re-wire and it will look un-sitely, which of course it will, this hut is brand new and I can understand why they dont want me hacking it about. But with the socket ring and light radial wired straight into the 16A female plug I dont see much option so I am open to ideas/suggestions?
Walec I'm getting a little confused is the internal sockets and lights wired to a Female PLUG or SOCKET
If it is a normal female socket I would change it as that means to utilise it you will need a male PLUG has a supply and that is dangerous. If you think about it a female socket supplies power, you want the reverse you want to supply power to the socket.
I'm not sure what you are going to do concerning the inside. It's not a good design feature to have sockets and lights on the same single protection device. What you have to do though is design your protection to the smallest cable CSA, you may find that both lights and sockets are wired in the same size cable, which should make it easier for you.
After what you say I would do as Richy suggests make it the same as a caravan hook up.
Sorry my explanation is not great, I meant internal sockets and lights wired to a female socket, 16A 3 pin, the same as a caravan lead. I like the idea of the caravan hook up, I am going back to look more closely at the wiring internally.
I don't understand why the light circuit would have a female plug on it, this obviously means the supply would need to be on a male plug which doesn't sound right.
I would just phone or e-mail the suppliers of the hut and ask them what they had in mind for the supply when they designed the electrical system.
Well, while your going back to have a look, .....How about some photo's please. That will make it much easier for others to give you ''sound advise''!!!
Shepherds Hut
Australia
walec,
walec,
