S Sparkette Today at 7:35 PM #1 Hi, I’m running a split con cable from a switch fuse in a meter cabinet to the house cu. Are you supposed to bootlace crimp the cores?
littlespark ~ Staff member Esteemed Arms Supporter Patron 51 minutes ago #2 Correct me if I’m wrong everybody, but isn’t split con only used by DNO? If it was standard SWA cable, I would say no the bootlace ferrules. They are more suitable for fine stranded flex.
westward10 ~ Staff member Admin Esteemed Supporter 32 minutes ago #3 Never seen a crimp on split concentric pointless exercise. You can use split concentric if you wish.
