Currently doing first fix in a football club changing room which includes 4 x shower areas
No M&E PLANS for installation
Understand the regs for a bathroom and kitchen just need a bit of advice for extraction rate for the room which includes the 4 showers for the volume of extraction it requires
Can't install fans through the wall as customers doesn't want it I was thinking either
Vent 1 x 9 inch fan controlled via a humidistat through the soffit which could be a issue as regards soffit to small or a fan directly through the flat roof prior to it being sealed
I'd be really grateful for your advice and if any fans you recommend cheers
