I
identi
Hi all. I've got a property developer who wants to take me on his books.
He mainly does large extensions but will be branching out into new builds.
I need to be able to do new fuse boards/changing , plus work in kitchens bathrooms and gardens.
I have nvq 3 in electrical and mechanical maintenance.
Did my 17th last year.
So I assume I need part p and napit?
So he wants you to be a chef, masseur and gardener as well as do the electrics.... :)
You don't say where you are but if you are in Wales or England, membership of a scheme does make sense.....
so....
is it you who needs it (scam membership)...
or just that he wants you to get it...
If your NVQ is in maintenance, I would recommend brushing up on building regs if you are going to be involved in new builds. I'm assuming your course didn't cover the aspects of installation involved with this.
Scam membership ????I need to be able to sign off my own work including fuse boards. I have extensive year's of experience doing domestic installs . Will part p and napit suffice to allow me to change consumer units and sign off muktpl circuits? ???
FFS, if you do have years of experience then surely you know this.
Call Napit and Elecsa.
You will need to join a part P scheme (commonly known on this forum as a scam) as the easiest way to notify your work to building control. Napit, Niciec, Elecsa, etc all run part P schemes.
When you say "sign off" I take it you mean this notification to building control, as you are already competent to certificate your work.
I am surprised with your extensive years of experience in domestic installs you are not aware of the requirements regarding part P.
I have nvq 3 in electrical and (1)mechanical maintenance.
No part P needed for mechanical, and who?
Part P is not a qualification, its a building regulation and as the others have said, there are two way's to notify....join a scam or pay LABC each time.
