C
cairns
Hi there,
I'm planning on rewiring my house and want to put in all the cables necessary to have sky HD in most rooms, How do I go about going this, I know I have to run coax to all the rooms, do I run CAT 5 aswell? How do they connect into the sky box? Any help would be greatly appreciated.
Cheers,
John
from your sky box location, run separate coax to each TV location. if you want to couple to internet, cat5e from patch panel to each.
You don't say whether you are going to use a single sky box or multiple boxes as this will change how you wire it also your dish will need a multi output LNB for multiple boxes
If you want to watch different channels at the same time in different rooms then you will need more than one box
Spot on jimmy.
I have installed HD to another room, but this had to use a magic eye to change channels and two super long HD leads with a booster half way along.
Worked a treat.
Need to be careful with HDMI as I believe the handshake signal can be lost over distance. I recently rewired my parents home and they wanted Sky HD in 6 bedrooms, 2 living rooms, 1 dining room and a kitchen. The only way I found to do this was with a 8 way HDMI matrix, running a pair of Cat 5e cables to each room and using Balun's to convert back to HDMI. Because it was 10 rooms and most matrix boxes only have 8 outputs the most cost effective way was to have 2 Sky HD boxes (1 in each living room) one of them used the RF output to the kitchen (not good picture quality but we felt it was the room least likley to be used for watching films) and the HDMI to the Tv in that room. And the second box was connected to the matrix going to all other rooms. You have to watch what the person downstairs is watching but I did manage to get a HDMI cable from the 1st box into the room with the matrix so worst case scenario is that you could have 2 Sky channels running through the matrix at any one time. It also had another 2 inputs so we connected a Blue-ray DVD player and PS3 to it and as the Balun's came with IR link you can change channels from any room and also the PS3 controllers seem to work from any room via Bluetooth.
I paid around £60 per 300m of cat5e cables from Blackbox, the Matrix was £1500 and the Balun's came in at around £80 each. The Sky HD is around £50 per month and we have to pay an additional £10 for a second card. It was quite an initial outlay but then again if you think about it, the LED TV's cost around £800-£1200 each (got a good deal at Currys for 2 of them - 47" Samsung 3d LED, 3D player and 3 pairs of glasses for £1500 each) and what's the point of a decent TV if you have a rubbish signal.
Sky TV + hd to everyroom
FreeSat, Sky, VirginMedia Forum
Thread Tags
cairns,
SimpleSimon,
