Discuss Sleeving Brn-Blk-Gry cores for SP. Is there a convention? in the UK Electrical Forum area at ElectriciansForums.net
I'm puzzled why it should be absolutely prohibited though: brn, blk, and gry are clearly legit phase colours, so as long as the remaining two are clearly sleeved blu & grn/yel at both ends, where's the danger?
There is a problem now that two colour systems exist, which is that a single-phase distribution circuit on the black phase (harmonised colours) would have a black line and a blue neutral, while one on the blue phase (old colours) would have a blue line and a black neutral. This is the only situation with completely ambiguous polarity, as in any 3-phase circuit the colours of the other phases imply the functions of blue and black. Requiring the line to be brown on a single-phase distribution circuit prevents possible confusion.
Historically, I did prefer phase identification colours and wired many distribution circuits that way. I would tag the line on a 2-core MI submain with the phase colour too.
I don’t know?
When I worked at Tate and Lyle, we used to use the phase colours for all circuits.
I dread to think what the trunking will look like now Black is a phase colour.
From what I remember the panels I designed for Tate and Lyle all phase colours were black, but every wire was numbered. It was also a control suit so not exactly the same as distribution.
Reply to Sleeving Brn-Blk-Gry cores for SP. Is there a convention? in the UK Electrical Forum area at ElectriciansForums.net
I’d appreciate your professional views on this question, as I’ve had 2 of the associated electrical bodies quizzed on this.!!!! ON changing/up...
I have a baffling problem with a newly-installed PIR floodlight and I'd like advice from the forum as to whether it's defective (and should be...
UK 2022 based regs question. Hello, I have a new extension and the builders electrician has required much of the house ( not asked for ) and...
If sleeving conductors at both ends, does it really matter which underlying conductor colour is being used for what? Background is that I’m...
Hi, Quick question and hopefully not too silly. In the wiring for a heating system, is the convention to use Brown sleeve at on all cables that...
