Discuss smoke detectors in the Australia area at ElectriciansForums.net
diditrain
Hi everyone, could someone tell me if there are any issues with having smoke detectors supplied from two different lighting circuits if i am using radio bases?
Many thank`s
Thank`s for the replies.
acat can you elaborate on cable being to BS5839?
If i was to take a feed to each detector are you saying that this should be different from standard twin and cpc?
Reply to smoke detectors in the Australia area at ElectriciansForums.net
I currently have a home with 7 interconnected, hard-wired smoke detectors. I have a hard-wired heat alarm in the garage that I need to have...
Hi all Recently we've been having a few issues with smoke and heat detectors.. been fitting them for years and years now mostly without any...
Doing work in a house the other day, and noticed they didn't have any smoke detectors... (well, one.. and it was a small 9v thing) So ive sent in...
I have a bathroom fan with a moisture detector that turns it on and off. It also has a control circuit to turn it on/off when moisture is not...
