Discuss Solar on a metal roof in the UK Electrical Forum area at ElectriciansForums.net
bigspark17
Hi all.
Installing some panels on a shed roof (trapezoid) just wondering your thoughts on earthing the roof. The roof sits on the wooden structure of the building. What should i do with earthing?
1- earth bond the roof back to garage cu
2- earth bond to a local earth rod
3- no earthing
Where so the solar panels' cables go? Many inverters check for leackage and shut down, so having the panels earthed does make sense.
I probably would bond the metal roof to whatever anyone could touch at the same time, so probably the garage CU as it would feed any sockets or appliances in there.
Reply to Solar on a metal roof in the UK Electrical Forum area at ElectriciansForums.net
Hi all. Installing some panels on a shed roof (trapezoid) just wondering your thoughts on earthing the roof. The roof sits on the wooden...
Hello fellow professionals, I'm currently facing a challenging scenario that involves the integration of solar photovoltaic (PV) systems on roofs...
Hi All, I own a country Villa out in the Spain countryside. Was having problems with water pressure so local tradesmen advised to get a water...
Hi wondering if you could help with some advice Been running an Essex/suffolk based electrical firm for last 20 years, mainly light commercial...
TNC-S main supply with 16mm swa supplying garage consumer unit from main consumer unit in house, then 4mm swa supplying pond equipment through...
