N
Newinthegame
Hello,
If an existing socket in a kitchen is being moved 6/8 inches should I be installing rcd protection now?
Existing 6 way Wylex with an additional 2way rcd board next to it fed from a 32 amp mini trip. Does this have to have a linked switch to isolate both boards at the same time?
Radial circuit from board....2.5mm or 4mm? It would supply a twin socket and spur for cooker hood.
"newinthegame". College beckons tomorrow so I need some answers and regs not available.
I'm not cheating...honest.
:yes: Thanks.
so post your thoughts, then we can comment.
Radial circuit 2.5mm via 16amp breaker?
seem to remember no for the linked switch so long as each individual main switch is marked so.
kitchen socket. It's not an additional socket only extending and not a special location so no?
but if extended cable is to be placed less than 50mm then yes to rcd.
pass or fail?
Newinthegame,
Top-Spark,
