hello lads
whats the work situation like out in spain me and my mate (both sparks) are looking for work any chance of coming over to give you guys a hand dont mind housebashing anything considered or pm me with some contact numbers cheers lads
Things here are not good. Even the Spanish electricians struggle to find work. Two major suppliers have folded in the last couple of months because there is not the demand for materials
The majority of homes / villas in Spain have a supply rated at 5.5kw controlled by a device called a re-enganche ( safety cut out overload with internal bi-metallic strip.) The earthing system is T.T with double pole MCB's and front line RCD. Usually the wiring system is flexible plastic tube and empalme boxes buried in the walls with singes used. A joy to rewire compared to the crap over here. Just don't try connecting a big oven or electric shower from the U.K otherwise you will find your re-enganche will weld open. .
