Discuss Splitting supply 3 ways in the UK Electrical Forum area at ElectriciansForums.net
Hello,
i have have been asked to rewire a building which is turning into a small shop, and a maisonette. The supply looks like a 16mm cable. And the builder had a dude from the DNO pop over. And to cut costs he has left some cable behind to run to where the new fuses are gonna be. Thing is the cable is a single core 35mm swa. It seems a bit overkill and also to use the cable id have to run 2 swa to each fuse. Is this ordinary when splitting the supply?
Reply to Splitting supply 3 ways in the UK Electrical Forum area at ElectriciansForums.net
Hi, while carrying out an EICR at a farm cottage on Friday i came up against a problem early on. Whilst measuring the Ze the reading i obtained...
Got an EV (Nissan Townstar EV) in my house, has a Zappi EV charger installed (by myself) and notified via ENA form to Scottish Power energy...
Hi everyone, A diversity question concerning 2 consumer units fed from 100amp DNO supply Background, So I have an 18th Ed compliant consumer...
Hi, this is a repost of the initial in diy as the only potential diy aspect is the prep ahead of a qualified person attending, this is hopefully...
Hi Just bought this 1960s house, will be doing full rewire. Incoming supply splits and goes through hole in garage to next door. This is a looped...
5K
