Discuss Spot the mistake in the UK Electrical Forum area at ElectriciansForums.net
davesparks
Mentor
The water clowns have been at it again, and it gave me a good laugh so I thought I'd share it.
They've installed a new waste pipe for the condensate from the new boiler in the loft.
The problem isn't immediately obvious but if you look close enough there is a clue.
If nobody gets it I'll post another pic which might help
Oh my, if that grey pipe is existing and for the purpose I think it is then someone is going to have a very awkward apology to the customer.
As I’m not much of a plumber - I’m going to ask - is the problem that the condensate drain is placed into a sewer vent pipe? Which might lead to methane being fed back, oops.
I went to one, plumber had connected pressure relief valve from hot water heater into extract pipe. Boiling water showered through the ceiling mounted extractor fan over one of the toilets, thankfully no one was in there at the time. I had to replace the damaged fan. There was some sort of investigation and I don't think the plumbing company got any more work there...
My son moved into a small rented new barn conversion late last year, within a week the bog was backing up. Investigation showed two soil pipes coming out of the ground, one to a septic tank and the other for the as yet not installed rainwater guttering going to a soakaway. Guess which one the plumber connected the waste to?
In fairness to him he did not install the drainage outside.
Did a really up market restaurant in York, rushing to finish before the opening. The toilets were directly above the spanking new kitchen and the plumber left the wastes loose on all the bogs. Opening night and they got through with the suspended ceiling getting a bit damp. Nobody noticed until the next day. What a filthy mess that kitchen was.
Water clowns ha ha ha ha that’s now an official term....I’ve got 3 plumber mates I’m off to abuse em! ?
Edit picture sent to em let’s see if any of em spot it!
Reply to Spot the mistake in the UK Electrical Forum area at ElectriciansForums.net
A few weeks ago I posted this in another thread...: The tripping kept occurring, so I went back and moved a likely candidate circuit to the...
Hi, So I'm trying to understand what's going on with my off-peak electricity supply, as something's wrong with it and I'm trying to determine if...
Hi all, I really hope this is the correct place in the forum. tldr; Oven and boiler take turns to trip the breaker, but I don't think it's either...
