A
Andy78
Been to look at a small job which i am doing next Thursday. Just running a couple of circuits from an older type Merlin Gerin multi 9 TP+N DB. All the breakers in there are SquareD KQ or KQE. I know these are the push on blade type, and I'm assuming they have just had the blade modules removed from the tops so they fit on the busbars.
My question is, does anyone know if KQ fitted in this way are a direct pattern match for the proper multi 9 C60 type breaker, or are they a close match that have been "made to fit"
I ask because I will need the MCBs before I turn up to the job, cannot remove the board lid before then due to it being a public building, and I have some KQ to use already.
Anyone come across this before ?
