A
Andy78
Been to look at a small job which i am doing next Thursday. Just running a couple of circuits from an older type Merlin Gerin multi 9 TP+N DB. All the breakers in there are SquareD KQ or KQE. I know these are the push on blade type, and I'm assuming they have just had the blade modules removed from the tops so they fit on the busbars.
My question is, does anyone know if KQ fitted in this way are a direct pattern match for the proper multi 9 C60 type breaker, or are they a close match that have been "made to fit"
I ask because I will need the MCBs before I turn up to the job, cannot remove the board lid before then due to it being a public building, and I have some KQ to use already.
Anyone come across this before ?
We use alot of merin gerin boards and I have never come across a square d kq fitting into one like you say the square d has the two clips on the top so it must have been removed. Might be wise to take a merin gerin/snieder just for covering all angles
Yeah I think it might be best. I know there is a chance of them being compatible with it being the same manufacturer, in fact some of the KQ are Schneider branded so they can't be that old.
If you buy a kq now it is branded up as Schneider anyway as are merlin gerin I think. The prongs on the top are just screwed into the terminal and can be removed. Personally I would get a merlin/ Schneider mcb rather than a kq only to remove part of it. they are effectively the same mcb though.
As Durhamsparky says they will fit, there all basically Schneider MCBs. The square d's just come with prongs on which are removable very easily. Pop the cover off the prong from the rear (oh er) and unscrew them. Then you have yourself a Merlin/Schneider MCB.
Having said that, I just buy Schneider lol.
But it's useful to know.
