M
Mark_Burgess
Why don't the company that installed the equipment and the company that supply the electric know what cutout fuses they have ! MORONS! :banghead:
How are we meant to fill out certificates if noone know who has been supplied, or what their meter is connected to?
I am being told to look at the carrier. All I can see is a ruddy great big grey plastic Lucy cover!
Useless arseholes want to charge to come out and take a look in a month or so time!
Unknown it is then.
try pulling 120A through it for an hour. if it blows in under 10minutes, it's 60A. if it takes the hour, it's 80A and it it doesn't blow, then it's 100A or a nail.
The cover just fell off, and I still have no idea, the supply cable must be near 150mm CSA.
Why is it I get jobs where the CSA is not on the armour sheath.
150mm . what's it feeding, a village?
It used to be a joinery, there are 13 boards in use, 3 not in use. They want a full plan drawn up aswell, good couple of weeks work here!
It would be an idea if when they upgrade the meter ie smart meters they have to pull the fuse anyway and put a new seal on it so why dont they just record the size on their hand held unit that automatically updates the meter details ie serial numbers.
Na too simple why ad an extra box for the trained (not an electrician) meter changer to fill a figure in a box or maybe we should keep it complicated as this is how they can make more money
After the cover fell off I got this picture of the fuse carriers, still no idea!!
The meter is wireless, there is an aerial in the room for it, apparently it used to give a reading every 30mins!
