Looks good to me.
U v w 1
Need to be offset by one phase form
U v w 2
Hi guys,
Trainee here looking into motors and motor controls. I came across these drawings trying to get myself familiar with them. MCC PANEL WIRING, GA and BOM Sample - https://www.slideshare.net/slideshow/mcc-panel-wiring/48503112#7 - Slide 8 shows a motor wired in star/delta are the corrections correct? I thought U1+W2 Should be say Red, U2+V1 yellow, W1+V2 blue.
Not sure if I've just misunderstood but it doesn't look right to me. Any help would be appreciated thanks :)
Just think of wiring a 3 phase motor in star then in delta. U1,V1 and W1 terminals are common to both. The link plates are doing what the changeover contactors do. It helps to have a diagram of the motor winding configuration. I don’t think the connections are correct on your drawing.
Hi guys,
The motor connections look ok, all your doing with the star and delta contactors is cross connecting the UVW windings, however the timer that controls the time the star runs before the Delta takes over looks as if there may be an issue, Star Coil should be operated when the timer relay is energised so that should be normally open, ( closes on being energised ) and the Delta coil should utilise the normaly closed ( it opens on the timer being energised) the line drawing shows both Star and Delta coils in the normally open position ... thats my take on it I may be wrong please let me know if I am.
