Discuss Sub Board?? How shall I go about it? in the UK Electrical Forum area at ElectriciansForums.net
Moaz
Im starting fresh electrical work on a new build. The mains is coming on the ground floor, from there I need to wire 3 more CU. What's the best way to go about it? So altogether there'll be a CU on each floor. Ground floor, first, second and third. 4 CU's altogether. What do you guys reckon?
What type of building is this, and what kind & number of circuits? House? Offices? Something else? Bit difficult to comment without more information.
Well you will need a cable pulling into each new DB won’t you. It’s hardly difficult to work that out was it if you knew what you was doing.
So I'm not clear what you are asking?
Re-reading the original post, it seems you've already decided there will be one CU per floor, and you want to know how to supply each CU from the intake?
Or is this still open, e.g. you could instead put everything in one plant room where the supply enters the building?
Reply to Sub Board?? How shall I go about it? in the UK Electrical Forum area at ElectriciansForums.net
Im starting a re-wire of a top floor flat, they have run an 16mm T&E with a 6mm earth from the ground floor to the 3rd floor feeding the CU...
I have been asked to change cu from old fuse board which has 6 fuses. Only 4 fuses are used. The first fuse feeds cooker circuit. This is not used...
Hi all, I have two questions regarding wiring and containment on commercial property stairwells in Ireland. We are currently wiring a 3 story...
Trying to organise a CU replacement at home. It's a 1930s property. It's got a 10way CU but with no RCD protection. Was after a larger unit with...
4K
