H
hamazz
Basically a friend bought a new house and just had a chance to take a look at services inside,
supply head/meter and CU
Single phase meter, what is the second bit on the left for on the supply head? is it to loop to next property, or is it a 2 single phases???
the consumer unit i know needs to be changed and made upto standard, any idea how old this one it? there is also another metal one in the garage that seems easily 40+years old that will need to be swapped to.
im guessing the meter needs to be changed too, the previous owner said they got a letter about it a while ago but never did anything about it.
hamazz
The thing next to the service head just looks like a fuse carrier with nothing connected to it, for whatever reason.
Fuse box, maybe 1980s ish with retrofit MCBs. Looking at the solid green earthing the wiring will likely be older than that.
Electricity meter is down to the energy supplier to deal with, they'll probably fit you a new smart meter if you asked them :)
you have a single phase supply with 1 extra unused fuse block.
i cant see anything wrong with the wylex mcb CU. ( other than some unsecured tails )
i cant see anything wrong with the meter.
what i do see is the completely bodged earth clamp connection on the dno cable which requires improvement
That's just an isolated fuse carrier ...connected to nothing!! If it has a fuse in it, half inch it, it could come in very useful in the future!! lol!!
OK the Wylex CU could do with updating to a new CU, but left alone, will probably see you pushing up the daises and still be giving a decent service of protection... lol!!! Who cares whether the meter is an old type or not, leave that upto the DNO or meter company!!
well, im going to get the dno in to swap the meter either way, was wondering whether we should do the CU after the meter has been done or not?? as we will be probably be renting the property so want to make sure it is upto standard somewhat
hamazz
hamazz
I have no idea why you're so obsessed with the DNO meter, what's the problem with it?? If the plan is to rent the property then it would be prudent to update the present CU. More importantly I would conduct a thorough EICR and correct any deficiencies found....
not obsessed with the dno meter, but if their going to swap it for free, then why not..
was thinking of doing the eicr report, but thought might aswell swap the cu and tidy everything up as there are a few bits in the house that seem way under standard... do things once and dont have to worry about them for a while
hamazz
hamazz
You sure this isn't Your property?? lol!!
the second fuse carrier is probably used as an isolator obviously not at the moment but at some stage
hamazz
If the property is to be rented out, there is a duty of care to those that occupy those premises
Although if you alter nothing the electrics may be up to "scratch" when they were installed but i would seriously upgrade all to the current standards before you move any tenants in
(i do a lot of work on rented properties and see many very rich landlords doing nothing to update the electrics etc, they have to regarding boilers so why not electrics ! i cant wait till electrics become as strict as gas works !)
