davesch
Situation is garden summerhouse fed by own 16A RCBO in consumer unit in garage over 4mm2 (overkill !) SWA . At summerhouse this goes to sockets (no FCU) and to lights via FCU with 5A fuse. The lights are all LED so consuming minimal current From the searches I've done it would seem that is okay, but one website claims - "Outbuildings, Garages and Sheds are all required to have their own fuseboard or consumer unit under the BS7671 regulations". It doesn't say where the reg say that, does anyone know, or is this rubbish ?
Why is that overkill?
It is rubbish, there is nothing in BS7671 to support this.
In a metal adaptable box using SWA gland. Twin and Earth cable via plastic glands to FCU and Sockets
What about the house end ?
Is there anything extraneous in the summer house ?
What type of earthing system ?
Terminated via SWA gland onto an 18th edition RCBO CU, nothing extraneous in the summer house. I believe it's TN-S, but actually asking on behalf of a friend who recently moved into the property and wanted to check it had all been done correctly and in particular whether there should have been a CU fitted in the summer house, hence my search and coming accross that website I quoted in the initial posting.
4mm² or 6mm² won't be overkill when someone comes along later wanting a Hot tub or heater or something else added.
Maybe the original installer expected to be called back or the customer asked for extra capacity.
Fair comment on reflection
Sounds fine but without it being actually tested then who knows.
I personally would have used a garage type CU as they are as cheap as chips.
Looks better
Easily add/alter
Save the cost of an adaptable box and fcu
Easier to isolate.
