^^ never seen it before, has anyone else? interested in what sort of installation
it replaces the banjo and the swa nut gives you somewhere to connect a earth to, great if you haven't got room for a banjo, say a small Plastic box.
I think some of the others referred to them as piranha nuts, but could be wrong.
- - - Updated - - -
http://www.tlc-direct.co.uk/Main_Index/Earthing_Index/Piranhna_Earth_Nuts/index.html
banjos at a national grid gas terminal in Scotland. ????????????????????????????????????????
Sure it wasnt fryin pans, us sweatys dont use banjos.:biggrin5:
havent seen them used widely as its a extra cost, that companies don't like.
But people i know that use them love them.
Handy to have a few in the van for those tight spots where a banjos give you ball ache.
They are a good bit of kit. Easier than drilling. Ive used them on the last few jobs Ive done where I had to fit an isolator switch for each AC unit, on a roof. Just easier than drilling into the plastic box/enclosure and fitting a nut & bolt. Not that expensive neither, if you take into acount the time it takes to drill the hole and fit the nut & bolt.
Jay
A/c isolators are the perfect home for them.
I've found when trying to order them on other people job they won't just because its a extra cost they think they can save. They don't see the 5mins of ****ing about they could have saved
