It should be…. A weatherproof gland into a weatherproof box should be weatherproof in all directions.
I take it there’s no room so bend the SWA up into the bottom
I'd prefer to do that in theory but the swa is running along a wall under the capping and looping into boxes for tap offs
Won't look that good going down and up into box
I would always try and bring it in through the bottom.
I would be happy to use the sides.
I have never used the top.
Am I missing something about waterproof swa glands
I always have trouble with the brass ring that clamps the armour . No issue with standard glands ?
The waterproof ones, ie CW20 instead of BW20 have an additional rubber ring that gets tightened around the cable, as well as the armour grip.
There are also the Storm type glands.
Ya I know that but it's the clamping ring I can't get the hang of
The standard glands dont usually have it
I saw the storm type glands must take a closer look thanks
I was just about to say the ring on some glands is tapered one way. Only fit one way
I’m sure they used to be much easier to fit 20 odd years ago for some reason.
