L
liddley
Hi guys, Need advice on sizing a cable for a temp supply. Am thinking of using SWA but not having used this type of cable much on domestics im not to familiar with its current carrying capacities .Are they similar to T+E? Any advice appreciated.
it's all in OSG.tables look under SWA. CCC of SWA is similar to T/E.
What is the temporary supply
for? I'm not liking the not
used SWA before! Whats your real job?
aye. what's he going to be growing.
Turn it in fellas, you really think I would be busting my nuts with this game if I was growing pot?
Have got a house that's up for rewire when its finished being extended. The mains position is inside the house at the moment cutout with 80A main fuse, meter and cu in kitchen cupboard. Northern power grid are moving the cutout from inside the house into a new external meter cupboard on the new extension wall. So I suspect I will be left with a shiny new cutout with 100A main fuse and a self connect isolator. Need to temp a cable from there to original position to get power back on until its time for the rewire. Was going to use a 16mm T+E and separate earth but think it will be a pig to protect it so hence the SWA.
Not sure on price difference between sy / swa / T+E. Similar also 16mm will carry 80 odd Amp.
