Discuss The dreaded BSOD! (blue screen of death) in the Computer and Networking Forum area at ElectriciansForums.net
littlespark
Supporter
Patron
Over the last week or so my laptop has crashed on me a few times and giving me the BSOD.
Its a few years old now, but wouldn't say it was ancient.
The error code it gives is UNEXPECTED STORE EXCEPTION
When I google that, it says that it can be caused by a few things, one being a hard disk on the way out.
It also told me to try sfc /scannow, but that hasn't found any problems.
Is there anything else that can cause this?
I do everything on this machine.... emails, invoices, even browsing on this forum.... so it hardly ever gets turned off. If it is the disk, i'm going to have to start backing up everything soon.
The laptop specs:
HP Compaq
Intel Celeron 2.16 GHz
8.00GB RAM
64-bit processor
Running win10 Home.
run the 'cmd' as an administrator and then type chkdsk c: /r
It will ask to reboot and let it scan the hard drive for bad sectors and errors.Be warned though as it can take many hours to complete.
As the other guys said,you need a new hard drive asap. SSD is the way to go.Samsung 860 evo is very fast and 500gb will set you back around £80-90.
See above re hoovering...
If its not the Hard disk it could be the RAM. Might be worth popping it out and cleaning/re seating it. If you have never done this before read up first and watch some videos, you need to be very careful to discharge any static before handling it, and don't touch the pins.
Also would recomend making a back up as first point of call if you dont have one. Dropbox is very useful for keeping a constant backup.
Make sure you have everything backed up! this is most important.
Look at it this way, something is failing and thankfully you've been given a few warnings.
Personally I think it's likely to be the hard drive that's failing.
I had a HP laptop doing just the same fault, turned out to be dry joints on the motherboard where the HDD plugged in.
I dismantled it, identified and re-soldered the offending joints.
Not a job for the fainted hearted but it worked!
hardware issues can cause all kinds of headaches to find such as bad solder joints, dirty connections, and heat issues.
while a poorly communicating hdd can cause a blue screen. the primary cause of getting a bsod is an unrecoverable resource call collision.
this can happen if hard drive is failing, memory failure, and many times if the hal file is drastically different as compared to the actual hardware (swapping a drive to a different computer is a good example of this)
its a major problem with windows machines!
The poor thing has been happy for the last few days. Fingers crossed, no more.
But it has shown me that regular backups are required for when the unthinkable happens.
I know Mac is so much better than Windows... but I am just a poor electrician. They cost so much more, even claiming it as an expense.
I am too old to learn how to use a Mac anyway... I mean, the "X" is in the wrong corner for a start!!
windows headaches are why i switched to linux years ago
pinguy linux was written in the UK and its dead easy to use.
everything works well out of the box. but if your computer has uefi (secure boot) you want to change the setting to legacy.
uefi does not like linux at all
Reply to The dreaded BSOD! (blue screen of death) in the Computer and Networking Forum area at ElectriciansForums.net
