Discuss They are called "pigtails"cpcs in the UK Electrical Forum area at ElectriciansForums.net
well presented, but twisting solid conductors and using wire nuts..... talk about polishing turds.
Reply to They are called "pigtails"cpcs in the UK Electrical Forum area at ElectriciansForums.net
Anyone tell me where to connect the two wires that switch the boiler on via the programmer and the 2 wires that call for heat on the ufh control...
Does anyone know what the cable in the picture is called? Or anything about it? Labelling on the outside is “E SPC Electric Cable 600/1000v” Its...
Hi been a while, im writing a report and need to know if there's a specific term for the (?) front of a dist board, as opposed to the inside of a...
I generally consider myself pretty up on heating systems but this has me slightly stumped… An otherwise very simple system boiler on what I...
Recently started a retrofit where the 3 phase dB has been fitted with bushes through the galv trunking. The single phase supplies outgoing have...
