I suppose the good thing is that wagos came on to the market. It does at least mean when this sort of work is done it is safer than just chockblocks. That is assuming he checked that the wires were up into the wagos properly. Given the lack of attention to detail it is quite likely there will be some loose connections.
Atleast their progressing to wagos instead of connector blocks.
You can report him to checkatrade. if you have valid information on a member they will remove them from the site unlike some websites... guy needs stopping as that is ---- poor.
What the bully Master, or the idiot that did the taping up, I'm joking Mate.
The ‘installation’ belongs to some friends. They have raised the issue with Checkatrade and asked if I could comment on the issues. I would love to but do not class myself as an experienced spark with the experience or expertise to pass expert opinion.
I could go through the BBB and list obvious breaches. 522.8.4 , 522.8.5. Lack of enclosures and sheathing of cpc etc.
They've raised the issue, not you and it certainly needs addressing. You can give them advice, as you're thinking, but be careful of getting involved, alone. Is there no one local, with experience and confidence for a bit of backing... off here, maybe?
At least they have maintained cpc continuity! Usually find lots where the cpc has been snipped off!
DIY /kitchen/bathroom fitter shoddy, cowboy, shameful, unsafe, scourge of the professional electrician. ive done 10 EICR or so this month and this is the rubbish you come across day after day and at least we have apparent CPC continuity although I doubt verified by the installer. its honesty depressing to see this “standard”of work being accepted by homeowners who know no better. Ps Landlords have got a big expensive shock coming as I’d say 80% of their Properties over 10 years old need at least a grand of work to replace fusebox/tails/bonding/ring continuity/lighting CPC issues if not full rewires that’s without the cost of redecorating and inconvenience to their endangered tenants
Your friends could report to ChaT - the wiring he/she had done was questionable so it required subsequent inspection and testing by a qualified and accredited (eg NICEIC) electrician who reported that ....... and did this remedial work so it complied with .....
I hope that was temporary and that they were coming back later to actually do the job properly and just ran out of the correct materials to do the job.....
