Rip the lino up. Then prime the sub base before tiling. If you have a screed sub base use a regular adhesive, avoid rapid set if you cant tile quick. If your sub base is green chipboard you need to use flexible adhesive and if you have regular floorboards you need to either overboard in ply or take the boards up and lay green board or 25mm ply and again use flexible adhesive and grout.
Very good advice. If the lino resists (like mine did) over board in ply and use flexy.
Don't do what I did and forget to trim doors down to compensate for the extra height of the floor and end up having to break the tiles up due to tiling one of your kitchen doors shut. :o
Thats a good idea, no need to measure up.
If you end up with an unsightly slither of tile along the plinth or wall you can easily drag the whole thing about to make it more pleasing on yhe eye.:lipsrsealed2:
i will take the lino up and lay it on the 6mm ply , if i were to put 25mm ply down and the adhesive and then tiles it would be 35mm higher than the hall , i would need a punty up everytime i went to get a beer out the fridge
The 6mm with flexi adhesive will be fine, are you going down for beer then tho I don't know I'm beeered out
i will take the lino up and lay it on the 6mm ply , if i were to put 25mm ply down and the adhesive and then tiles it would be 35mm higher than the hall , i would need a punty up everytime i we nt to get a beer out the fridg's e
I guess your going over floorboard's then?
Use a good adhesive like Ball rapid set and screw that ply down good ( at least 20 screw's / sq metre).
Most of all, take you'r time. You will have to look at that floor for many year's. Mix small amount's of adhesive untill you get the hang of it.
a good bit of advice is do as many cuts as possible before even mixing any adhesive...dry lay the tiles down....it is much faster in the long run......and make sure you spread the floor...you may need to back butter the tiles too if the floor is not flat....but have fun :-)
if you don't want the trouble of lifting the lino, you could always tile the ceiling, but wear a hard hat.
