S
Spudnik
Afternoon chaps,
Just arrived back after digging to locate an incoming TNS lead sheath cable ready for the DNO to relocate.
Now, after a couple of hours going through brick rubble and the usual stuff you find, i came across, what i thought was a water main.
Brilliant, i thought, cable will be around there somewhere - not.
After another hour of digging, i discovered eventually that the supply cable is in fact inside what i think is a 30-40mm steel tube!?!?:confused:
Has anyone come across this before?
I have done a fair few over the years and TNS have always been lead sheathed.
Cheers
J
Maybe just down to the builder, who stuck a bit of pipe in the ground and backfilled when the cable team arrived and were told about it, found their cable passed through saving them a trench so did'nt argue.
You do see some funny ( WHAT THE! ) things at times.
It does seem a bit odd, though im not complaining.
Just not used to seeing it like this.
i have never dug a hole to find the supply auth incomer as that is what i pay them to do
SSE do not dig holes on private property anymore, unless its in the pavement/road.
Its all down to the owner.
Well, as an update, SSE came, took one look and ran a mile!:D
No, basically they have to shut the road down through a link box in the pavement. cut the pipe in 2 places to access the cable and then switch back on.
Quite a common installation around that area apparently.
Anyhoo, the cable pullers fitted the cutouts in each of the flats and installed some funky MET's:
and they think putting "seals must not be broken" on the board will make a difference!
