I
in got a clue
So im abit stuck at the moment on wiring a shed that's about 1m from a house but every where is concrete around the shed and its quite thick so using a earth stake is pretty much out the question really, my first question is dose the shed have to have an earth stake or can i use the the earth from the house?? Im shore iv heard once that if you don't have a water or gas supply you can use the house earth? im running a 6mm on a 32A/32mA rcbo from the diss-board
