G
ggg79
Hi,
I should start by saying I am extremely bad at DYI and know very little about the world of electricity :-) But I am hoping someone on this forum can help.
I have two ceiling-lights in my flat. They used to work fine until one of them blew. At that point an electrician came while I was not home to do some work and took the bulb out of one of them to replace the living room one (which is more important) since he did not have the right bulb at hand to replace both.
This is what I am left with:
The first picture is the light in the corridor - the second picture is in the living room.
I tried to remove the one in the living room but it just keeps rotating endlessly when I try and unscrew it.
Similarly I cannot find a compatible bulb with the connectors in the one from the corridor.
The question is:
- how do i replace the light in the corridor?
- how do i remove the bulb in the living room?
I am sure this will sound obvious to all of you, but please do have mercy in your answers hehe :-) I am indeed in the 'dark' :-)
If your going to replace the light fitting I. The corridor then I would recommend getting a local registered electrician to pop over and do it, won't cost you much at all.
You need something like this
and they don't unscrew, they usually pull out
Thank you David that seems to be exactly what I need!
Thanks to Dan too - I do agree, I have had nothing but problems with these fittings where as the rest works perfectly fine with standard bulbs that can be bought anywhere.
best place for those fittings.......
