Discuss transformer beneath bath in the Industrial Electricians' Talk area at ElectriciansForums.net
I am going to install an e.l.v fan in a bathroom.The nearest place i can site the transformer is beneath the bath.Which i interpret in the 17th is outside any zones if the side panel is accessable with a special tool i.e could be a screwdriver.I presume the transformer does not have to be ip rated as it falls outside protected zones.Can anyone confirm this is acceptable please?There is no other place i can situate the transformer that is accessable really.!!! and obviously safe.
Pretty obvious i know,but just to add primary side 230v & secondary 12v or there abouts:D
I can't speak about UK rules, but what I can say is that some factory-built baths come with one or several transformers and various similar electrical equipment already installed below the bath. Something pretty catastrophic would have to happen to the bath for the transformer to get wet under there. Barring other special rules, I wouldn't hesitate to place it there.
absolutely - its outside the zones
I am just fitting a supply for one of these space age 'steam' showers, with a radio, lights, MP3 connection (and i am not sure but i think its got SatnaV)
so its a socket under the showerbasin - no problems:)
Why the need to have it so close?
Read the instructions first bet there is a table giving distance between fan & transformer & csa of cable to be used over said distance.
Xpelair LV100 I've just firstfixed the tranny is in the airing cupboard some 12 meters away from the fan itself.
Cheers lads thats what makes this site so good,i appreciate everyone taking the time to answer my question all noted and taken on board.Should have said couldnt mount tranny in loft as it is a flat& concrete ceiling.Suggestions about putting near triple pole isolator,which i normally fit outside bathroom above door,would this not look a bit ugly and obtrusive?? without sounding ungrateful for the idea.
I have on two occations put them in the stud wall beside the TP isolation switch above bathroom door, then installed a small white plastic access hatch that I got from B&Q.
Reply to transformer beneath bath in the Industrial Electricians' Talk area at ElectriciansForums.net
Well....wiring in a 1750s thatched cottage attic, not wiring made from thatch 🤪 One we have been letting for over 20 years (as well as enjoying...
4K
I’m in the process of changing my old downlights in the bathroom , I put them in years ago with advice from my late father who was a sparky, these...
Client with a 50s house that has apparently always been like this wants to change their self standing gas cooker, and obviously fitters are not...
I have a customer who has 4 12v spotlight that are intermittent. The original installer decided to install the transformers where they couldn't be...
Hi all I need a bit of help from the wise wizards I mate has a heavy duty mig welder which gave up the ghost on him I have had it apart the...
