Existing Labgear LDL216 TV distribution amplifer working well with 2 inputs (TV and DAB) and 14 outputs. The amplifer is in the roof space and the inputs come directly from the aerials about 3m away on the roof.
There are two spare outputs but I need an additional 10 outputs. I can't find a similar distribution amplifer with more than 16 outputs. Any ideas?
I imagine there will be one available, but if not then split the feed into two first and feed into 2 multiways. Obviously assuming signal strength is good. Daz
Hi there, usually for this many outputs you put a launch amplifier in place of the existing amplifier, then use a series of splitters (f type) to get the correct amount of outputs.
Sent from my SM-G920F using Tapatalk
Thanks for the tips. From what you say I can split the signals from the aerials before or after the existing amplifier.
To avoid modifying the existing cabling I think I shall split the signal before the existing distribution amplifier and use a second distribution amplifier for the new connections. To check that the signal strength is sufficient I can put the spiltters in place first and see whether the existing feeds are still working OK. Total number of feeds will be 24, 14 existing ones plus 10 new ones.
i wouldn't so it like that tbh, the way the signals work these days, quality far outweighs strength. every split will add some noise to the signal. Amping the signal before any splits ensures you amp the best quality signal you can. buy yourself a decent amplifier (a launch amp will probably be too much for 24 outputs) and put that in first, then a 2w splitter, leading into 2 12 way splitters.
doing it this way will give you a nice clean even signal to every output.
though before doing any of this.... you really should check what signal your already receiving
