Discuss Type A RCDs Vs Type AC in the UK Electrical Forum area at ElectriciansForums.net
The reason we should install DP (switched neutral) RCBOs in a TT system is only when an up-front RCD (100mA S Type) is installed so that we achieve selectivity and avoid nuisance tripping from a neutral - earth fault which would then trip the up-front RCD in fault conditions.
How many of us own the appropriate DC RCD tester to test Type A RCDs?
You'd hope everyone who needs one does, though this is unlikely to be the case.
My MFT (Megger 1730) is capable of testing types AC, A and B RCDs and I think most common testers are capable of AC and A type.
Reply to Type A RCDs Vs Type AC in the UK Electrical Forum area at ElectriciansForums.net
I was wondering if someone might be able to help either confirm or change my understanding on the use of S-Type RCDs. I believe that they can be...
A friend of mine asked me to look at here PV system as she is not getting any power (and thus money) from it. First real issue is the Aurora...
5K
