C
confused
First of all, hello :waving:and thank you in advance for any help in the following.
I was checking my meter reading and I noticed some black tar type stuff had leaked from the main cable by the main fuse inlet. Also the back board that its fixed to was crumbling (old chipboard) so I fixed a batten behind the board and bolted it to the wall. I called my supplier and they are sending (TWO) engineers to fix the problem. One for the main fuse and one for the backboard?
I told them that they sit next to each other and can be done at the same time…..think I started a union war, fuse-man not allowed to do carpentry work!!! Anyway the fuse-man is coming on Friday.
Now back in the early eighties I fitted two RCD boxes (a seven and eleven) with a split tail box plus a separate trip switch. I have each room going to its own fuse. The outside electrics to my log cabin (35 mm) was done by a sparky, this has its own RCD for power and security lights.
Do you think this tar leak is through age or have I inadvertently overloaded somewhere along the line. I also upgraded the earth wire to six mm which is connected to the main incoming cable. I am unable to post a photograph because I am a new member.
