It was so obvious that you were lying.Yes fella, but like i said before its nephews money up to him...and NO I HAVE NOT DONE IT....i am just relaying what i have found out today
thats why i'm double checking....micknew, if i wanted to do it i would've and used the correct wire..but i'm not qualified...be constructive or **** off you ********...i'm trying to help my family you ****ing moron.
OK thanks for that, who is DNO and how can I contact them?DNO are responsible up to the meter. the meter is the responsibility of the supplier, which may or may not be DNO. after the meter is down to the owner of the propery.
Thanks, Alan
This is a diagram from one of UK powernetworks help sheets so they are pretty stuck if it is the service head, it is down to them, try and contact the duty engineer, if you can.Thanks Richard, that diagram looks clear, does it come from some regulations that I could quote to UKPN? because it's a block of flats and UKPN says they are responsible only as far as where the cable enters the building from the street.
Also, if it's on another thread, do you know offhand which thread?
Thanks, Alan.
I have just reread this and I notice it is the individual cut out for one flat, this would normally be after the meter, as anything upstream of the meter would be supplied from three phase incomer and would not be specific to the flat.hi Andy and thanks. My local DNO is UKPN and they are disclaiming responsibility for a faulty cutout box upstream of the meter, it's a block of flats and the faulty cutout box is one for an individual flat. My problem is UKPN say they are not responsible, but I am trying to find out if that is right, and who is responsible?
Thanks Alan
