Hi, I am writing in desperation as whilst I am a fellow engineer, I can only do mechanical and not electrical ! I wondered if anyone could help with a technical issue I am facing.
I want to control an extractor fan by water flow to the shower so that the extractor fan only runs when the shower is in use (the extractor also has a timed over-run which would be good to retain )
Do anyone know if it is possible to use an EHC flow sensor
EHC Shower Flow Sensor - https://www.electric-heatingcompany.co.uk/ehc-shower-flow-sensor-p129
to control the extractor fan?
Envirovent Silent 160 MV Ultra Quiet SILMV160/100T Compact Inline Fan | Extractor Fan World - https://www.extractorfanworld.co.uk/envirovent-silmv160100t-compact-inline-fan--timer-4367-p.asp
The extractor does NOT support volt free switching as far as I know.
I have looked into using a relay between the EHC flow sensor and the fan, and these components below have been suggested but whether it will work and how to wire them correctly is beyond me.
Finder Pluggable Module 95.05
FINDER GENERAL PURPOSE PCB RELAY, 40 SERIES, POWER, DPDT, 24 VAC, 8 A
I have attached a very rough sketch of all the terminals I have so if anyone can tell me
a) If it will work
b) How to wire it up
I will gladly send you a case of beer
Is anyone able to help at all?
Many thanks
Matt
Yes that will work, the flow switch appears to be rated for 240V switching as far as I can see so you can wire the fan as normal with the flow switch connected where the light switch would normally be.
The extractor fan be controlled by a volt free switch, a normal light switch is a volt free switch!
That's an expensive flow switch! There are some, or were, electric shower booster pumps which have flow switches external to the pump itself.
I once salvaged one from a scrap pump and used it in a control system for something else, but I can't remember what pump it was from. In the absence of scrap pumps, it may be available as a spare part if you can identify one.
Can't see any reason to include a relay. Just connect it across the permanent live and switched live terminals of a timer fan.
Not sure that a working light switch can be called volt free.
Well it doesn't provide a source of voltage. Any volt free switch which is in use will have a voltage present on some or all of its terminals.
A volt free switch is a switch or set of switching contacts in a piece of equipment that you need apply an external source of voltage to in order to use it.
All the extractors I have fitted need a switched live in on the timer models they also need a permanent live.
Yes, as I said above the flow switch can be connected in the same way as a plate switch would be. That is to say connected between the permanent live and switched live.
As an Amazon Associate we earn from qualifying purchases.
a) If it will work
Many thanks
Matt
Is this a bathroom/toilet or just a shower room ?
Where would you connect the flow sensor ? Hot or cold shower feed.
Would you shower with no light ?
I would have thought a humidistat fan would be the best option, as it would only run when actually needed.
Either would work - unless you take very hot or very cold showers then both will have flow. But the hot will have flow first.
FWIW, one of our rentals has a pumped shower drain - low entry shower fitted for previous owner. That is triggered by flow switched in the supply pipes. Though only one is connected as the clueless ****wits who installed it were clearly incapable of realising that a ball will only drop under gravity if you mount the switch in an upwards sloping pipe.
SWMBO does. She'll also switch the fan off (if it's already on, manually controlled) before showering as the noise annoys her. She'll then complain about the effects of the moisture !
I would have thought a humidistat fan would be the best option, as it would only run when actually neneeded
There's a pretty good correlation between running a shower and requiring extraction.
Lets clear up some confusion.
When people say "volt free contacts" they don't normally mean there's no voltage on the contacts. It means that in rhe absence of an external circuit & supply, there is no applied voltage on them.
So the light switch on the wall does qualify as volt free because the switch itself does not apply voltage to the circuit - that voltage comes from the circuit it's connected into.
Contrast with systems where the contacts are linked to an internal power supply. So, for example, the warning light relay on a powered gate/door controller does not (typically) provide volt free contacts. Instead, when operated, the connection terminals provide power for a light - typically the same 240V AC the unit runs from.
1) Though only one is connected as the clueless ****wits who installed it were clearly incapable of realising that a ball will only drop under gravity if you mount the switch in an upwards sloping pipe.
2) SWMBO does. She'll also switch the fan off (if it's already on, manually controlled) before showering as the noise annoys her. She'll then complain about the effects of the moisture !
1) is a perfect example of why I extended my electrical contracting business to include plumbing and heating.
2) is a perfect example as to why I wire bathroom extractor fan isolators into the lighting supply to the room, so that if it's switched off, the lights don't work either. Simplifies including a 3A fuse as well.
