Hi, I am writing in desperation as whilst I am a fellow engineer, I can only do mechanical and not electrical ! I wondered if anyone could help with a technical issue I am facing.
I want to control an extractor fan by water flow to the shower so that the extractor fan only runs when the shower is in use (the extractor also has a timed over-run which would be good to retain )
Do anyone know if it is possible to use an EHC flow sensor
EHC Shower Flow Sensor - https://www.electric-heatingcompany.co.uk/ehc-shower-flow-sensor-p129
to control the extractor fan?
Envirovent Silent 160 MV Ultra Quiet SILMV160/100T Compact Inline Fan | Extractor Fan World - https://www.extractorfanworld.co.uk/envirovent-silmv160100t-compact-inline-fan--timer-4367-p.asp
The extractor does NOT support volt free switching as far as I know.
I have looked into using a relay between the EHC flow sensor and the fan, and these components below have been suggested but whether it will work and how to wire them correctly is beyond me.
Finder Pluggable Module 95.05
FINDER GENERAL PURPOSE PCB RELAY, 40 SERIES, POWER, DPDT, 24 VAC, 8 A
I have attached a very rough sketch of all the terminals I have so if anyone can tell me
a) If it will work
b) How to wire it up
I will gladly send you a case of beer
Is anyone able to help at all?
Many thanks
Matt
Finder Relay 95.05,Finder Pluggable Module & Finder Mount Relay 16A 230 Vac Unit | eBay UK
Finder Pluggable Function. 230V ac Coil, 16A Switching. Finder 95 250V ac Screw Fitting Relay Socket, for use with 40.52, 40.61, 44.52, 44.62, 40.51 Series Relay 95.05SPA. Finder PCB Mount Relay.
ebay.us
a) If it will work
Many thanks
Matt
