J
jamagi
Hi,
I'm confused with testing leads and items with adapters, I've got an Apollo 600 PAT tester. My items are mostly 15amp so I need to use a 13->15amp adapter to connect it to the machine. When I test it using the adapter it always fails on the resistance test. I've tried (to test a theory) by putting a 13amp plug on the item and testing it directly, at which point it passes. Obviously that's not a solution to the problem, but it shows me that the item is fine, and the adapter is fine. When tested together though, it fails. So how do I test these items?
I have a similar issue with IEC->IEC leads that need an IEC->13amp adapter... in fact ANY item that uses an adapter seems to fail the resistance test.
It seems the tests are only designed if you plug them directly into the machine, but the vast majority of my items are either 15amp or 16amp. I can't plug any of those directly into the PAT tester. Advice please?
