Discuss V pro dimmer up in smoke in the UK Electrical Forum area at ElectriciansForums.net
hello guys
I have been using the varilight v pro for quite some time now and today turned the power back on and the dimmer worked perfectly well, dimmed up and down x4 5w megaman LED GU10 lamps.
Then after 30seconds the switch started smoking.
checked common and switched feeds are correctly configured and turned the juice off.
What could have cause this to happen I am stumped guys as a second V pro also done the same thing.
I then whent for and Aurora One and was fine.
Reply to V pro dimmer up in smoke in the UK Electrical Forum area at ElectriciansForums.net
Morning All Got little bit situation going on, causing multiple visits (luckily only 2 mins drive from where we are.) Client not 100% happy with...
Hi :) I'm currently renovating my outbuilding. My electrician has fitted 10 conduit LEDs (that support both leading and trailing edge) and x4...
DIY query Have narrowed down the source of an occasional trip to one light circuit which is a varilight v-pro master dimmer slave set up. This...
Hello everyone. Thank you in advance for any help you can provide. I tried installing a dimmer to a 3-way circuit. The dimmer has a hard...
I have the typical LED on Dimmer switch. All the lights flicker in my house are very inconsistent times. By let me clarify by saying all the...
