This thread uses a prefix to highlight that the thread involves something central heating related. Try to use prefixes more often peeps.
F
feebs73
Has anyone done a s plan plus with this boiler, I have the instructions for the boiler and I can only see a L/N/E terminal but cannot see a S/L terminal, would it be where the 230volt room stat should be the RT terminal? Or does this boiler not have a pump over run.
thanks feebs73
hi sure it does have a pump over run so should connect s/l to rt terminal they recently changed boilers does it have link fitted on terminals 3 and 4 or just a removable plug with rt on it
Hi jaydee81
This boiler does not have the numbers on the terminals, this is what is causing the confusion, also there was no link across the terminal where the rt connection is.
thanks feebs73
is the new style boiler then the connections should be removable plugs should be one for l/n/e and another two pole with rt on the other side is not used wire s/l to rt
