M
Marvo
I have read on the forum several times that if a VOELCB no longer operates as earth leakage protection, ie it's faulty, it can still be used as an isolator. This has always struck me personally as being bad practice, if a device is faulty in any way then it's faulty full stop and should be replaced. Why do the UK regs allow a known faulty device to remain in service? Surely if it says VOELCB on the front of it then it should be capable of performing in the way it is labeled. Surely also you wouldn't want something that's already known as being faulty performing a task as critical as isolation.
I scoured through our local regs to find out if that was the case also in South Africa and was pleasantly surprised to find it isn't. There's a clause that basically states if any protection device can no longer perform any function it was originally intended to do so then it must be replaced even though it may still be adequately performing other functions.
The original function rarely worked anyway, not because of any internal fault, just that the systems these units were being incorporated into, had parallel earth paths which in most cases nullified the usefulness of the leakage side of these units!! Taking away the leakage side of these switches, and it then becomes a very good means as a DP switch if left in place. In fact if anything, a far better specified DP switch, than the normal over sized crappy DP switches they sell today. Can't for the life of me, see any problem with leaving these old VOELCB in place after removing the leakage operating side of things, as solely a DP switch... Remembering of course the vast majority of them were only rated at 60A, so no good if service head fuse uprated to 80/100A. I wouldn't go out of my way to save and reinstall such a unit at another installation, but left in it's original place is fine with me!! lol!!
I don't have a problem with the VOELCB performance as an isolator as such I guess it's the general idea of leaving a known faulty or partially faulty device in service. If it was a cheap 5 quid Chinese RCD from EBay that no longer worked but the requirement that originally made earth leakage protection necessary was no longer there would you be equally happy if it was left to be an isolator?
It's the across the board general principal of it that I'm not comfortable with, amongst other things if I see earth leakage protection in a DB I'd expect it to work as earth leakage protection. Same from the customers point of view, if it's there surely they should have a reasonable expectation it's fully operational and their installation is protected accordingly?
It's the across the board general principal of it that I'm not comfortable with, amongst other things if I see earth leakage protection in a DB I'd expect it to work as earth leakage protection. Same from the customers point of view, *if it's there surely they should have a reasonable expectation it's fully operational and their installation is protected accordingly?
That's the difference, those old VOELCB's were very well made unlike the cheap Chinese stuff. (and not all Chinese stuff is bad by the way) As i said before, in many instances there wasn't any fault with the actual units, they were defeated by the installation itself, by parallel earth paths. I'm not saying i would leave these converted older switches in place as a matter of course, but i can't see any reason not leave them in place.
Just Remove the Yellow or Red test button and the trip relay (easy operations) and your left with a perfectly good DP switch. It only takes a sticky label on them to inform anyone that it's now just a DP switch for isolation only. The Brit's love using labels sticky labels on CU's and the like anyway...lol!!
* If the VOELCB was the only form of leakage protection on an installation then obviously it would need to be replaced with an RCD. But in most instances, what we have been talking about, would be in situations where a CU change had taken place, and where RCD protection was now located at the CU. The converted VOELCB being located in a perfect position for isolating the whole CU installation. (ie, no need for removal of DNO fuses)
I agree not all Chinese stuff is bad, it's just an example.:)
Okay, here's another one, what if a switched socket outlet had a switch that no longer worked, would it be okay to leave it in service just as a socket with a non-functioning switch?
To be honest I wasn't really trying to single out specific examples and debate them individually, I was questioning the across the board general practice of allowing partially damaged or partially non-functional items to remain in service.
