M
Marvo
I have read on the forum several times that if a VOELCB no longer operates as earth leakage protection, ie it's faulty, it can still be used as an isolator. This has always struck me personally as being bad practice, if a device is faulty in any way then it's faulty full stop and should be replaced. Why do the UK regs allow a known faulty device to remain in service? Surely if it says VOELCB on the front of it then it should be capable of performing in the way it is labeled. Surely also you wouldn't want something that's already known as being faulty performing a task as critical as isolation.
I scoured through our local regs to find out if that was the case also in South Africa and was pleasantly surprised to find it isn't. There's a clause that basically states if any protection device can no longer perform any function it was originally intended to do so then it must be replaced even though it may still be adequately performing other functions.
