Discuss Wagobox in the UK Electrical Forum area at ElectriciansForums.net
C
Chris sparky
Evening chap.
I have a job coming up soon and part of It involves moving the consumer unit.
Im thinking of using the Wagobox topjob line of din rail terminals and enclosure. Neatness and easy of installation are the key factors here obviously.
Has anybody on here used them before and were they any good?
Prices see good but maybe some of you know of a Better alternative?
Apologies for any typo's im using new touch screen tablet and my fingers are like tennis racket handles lol.
Cheers
Im not sure about your exact needs but you could just use and adaptable box and either through crimps, wago's or connector blocks. All would fit in an adaptable box and I'm guessing would be cheaper??
Jay
The Wago box and din rails would make a nice neat job, just be sure the customer is aware there will still be a big box where that previous big box used to be.
I haven't used the wago ones but I have heard they are easy to use., however it is amazing how fast the cost jumps once you realise how many terminals you will need.
Explain why?? I understand the connector block but why not the Wago or through crimps???? Both will achieve the same outcome at a cheaper price.
Because a big wodge of crimps isn't as nice to work with as a neat row of labelled terminals with the cables fanned out into them. Sometimes it's not all about price!
Simple you should not crimp solid conductors. It reduces the CSA, leaves the conductor weak where it enters the crimp and the crimp will not give an adequate connection. Crimps on stranded only.
din rail and connectors in an adaptable box for me. a rat's nest of crimps or loose wagos rattling round in a box is a no go.
Dont get me wrong tel, if the customer is willing to pay for it doing this way then of course its the best way. But people dont want to pay loads for something thats going to be hidden away in a box anyway. Neatness doesnt enter their brains. Just the cost!lol
Absolute rubbish man!!!
Care to back that up with some facts ??
i have come across a lot of loose/ burnt connections when solid conductors have been crimped especially with cheap crimps and even cheaper crimping pliers.
Try a wiggle and pull test next time you crimp solid. I can bet you will either loosen the connection or it will snap with little movement. Now try it with stranded. You will find it is different again. There is a good reason the MOD would not allow crimps on solid but would on stranded.
The above is referenced to standard cables used in domestic situations not large LV and HV conductors that still are crimped.
Only my opinion you do what you like. It will provide remedial works for someone else to repair. Do it in my house you would be ripping it out and starting again.
Not a chance mate!! I do it right first time, every time. And I always use proper crimping tool and I double crimp and test.If the crimp comes loose after a tug, It comes straight off and I start again. If its done properly, it is a maintenance free joint!
Jay
P.s. I also use decent crimps.....not the cheap crap from ebay!!lol
Jay
Reliable joint then ? See post #8
If done properly yes!!!! But there is always a chance of human error like with any joint making. There are loads of threads on this subject and half say there ok and half say not, like with many things, we always assume our way is best.lol
But there is nothing to say not to use them on solid cores!
Label the wires, put in wago cage clamp connectors into an adaptable box. Din rail looks great but hopefully there will be no need to open the box again and save a bit of money. It can still be done neatly without a din rail IMO.
Thanks for all the replies and opinions lads. Going to go for the wagobox as i'd worked it into price anyways. Will be a tidy job and enclosure will be in cupboard so customer ok with that.
Cheers
Hi I'm electrician anyone in hit need to do any job or I looking for work I have 13 years Electrec experience And I'm very good in TV CCTV audio system installed if someone interest pleas contact me
I'm guessing you're not in the UK mate, if so then you should be told this is a UK based forum populated by UK based electricians (with one noteable exception)
Dammit I forgot about Andy being SA and Gnuuser in US and probably a few others too. Sorry lads.
Clucking bells, I'm going to use the first rule here-When you're in a hole, stop digging.
- - - Updated - - -
PS, Git! :)
wago boxes and din rails make for a tidy looking setup.
on the note about the crimp connectors
its one thing that needs paying attention to is properly crimping them
all too often I find them crimped incorrectly (staked on the seam side)
stranded and solid core will easily pull out of them.
most of the manufacturers of crimp connectors have a picture of how to properly crimp them.
its when people rush a job that they often crimp them wrong.
when i catch my apprentices doing it wrong they buy the beer :rofl:
Was going to use the Wago DRE-5, but with about 30 Top Job-S 2010, the whole thing comes more expensive than a populated CU. The one web site I've found seems only to sell the connectors singularly and not in packs. Anybody can suggest suppliers?
Reply to Wagobox in the UK Electrical Forum area at ElectriciansForums.net
Ferrets are known for being small, resourceful, and incredibly clever. They can solve many problems by fitting into tight spaces and doing jobs us...
Someone asked about abbreviations used here. So I tried to copy a list I made elsewhere: A/C Air Conditioning AC Alternating Current ACB...
5K
L
Back again! Im currently doing some garden lighting at my parents place and need some help on the switching arrangement. I ran all armoured's(9)...
B
Prefix - I've tried to post this in automotive, but it would not let me. This may be because I have not been recently active. Apologies if this is...
P
Folks, Here's the story: money difficulties and things, and I ended up puling the tails out of my consumer unit and straight into the bulk head...
